1974 DT125A Build/Restore
Replied by Gr8uncleal on topic 1974 DT125A Build/Restore
Daiichi are a good quality aftermarket product.
The following user(s) Liked this Post: torqueflight
22 Nov 2023 00:57 #151
  • torqueflight
  • torqueflight's Avatar Topic Author
Replied by torqueflight on topic 1974 DT125A Build/Restore
It looks like my points are permanently on the plate. Most of the points dont look like the same type of mounting. Am I going to have to buy the mounting plate too? I have a 125a with the generator.
Also might be having a problem with the spark plug boot. I took it apart and I cant get continuity through. Maybe part of the intermittent spark problem, IDK.
Pulled the head and jug off tonight to see whats up with the crank play when I wiggle the part with the weighted wings on the generator. Looks like the crank has massive play on the left side. Could of been from the bearing not spinning from rust and now its flat spotted. Now theres scoring on the cylinder when there wasnt before. The play in the connecting rod seemed fine though. Kinda pressed for time with some other stuff so I need to get this bike up and running and out of the way, so I might try and see if I can do a quick replacement on the bearings and seals. Then just do a ball hone clean up on the jug and call it good for the time being. Anyone know if a ball hone or the flat style hone is better? Also what size would I need, when I measure the cylinder with calipers it was just under 56mm.
Also how much of a PITA is it gonna be to separate the cases?
I assume Im gonna need some dry ice to freeze the bearings too.
Last edit: 23 Nov 2023 00:59 by torqueflight.
23 Nov 2023 00:50 #152
Replied by Ht1kid on topic 1974 DT125A Build/Restore
i.imgur.com/HgB7jAM.jpg
  This is from a AT2 should be the correct points for yours according to partzilla the plate comes with genuine Yamaha points.
23 Nov 2023 07:45 #153
For your bearing and seals All Balls 24-1073 kit is a quality kit MarkT can confirm if this is correct
The following user(s) Liked this Post: MarkT, torqueflight
23 Nov 2023 08:13 #154
Replied by MarkT on topic 1974 DT125A Build/Restore
Yes 24-1073 for crank bearings and seals.  OEM quality.  One kit on ebay for less than $25 shipped!  Haven't seen that price for a while for both bearings and seals..
The following user(s) Liked this Post: Ht1kid, torqueflight
23 Nov 2023 08:36 #155
  • torqueflight
Can you like what you guys are seeing? When I put that part number a bunch of stuff comes up. Is the kit youre talking about the one with the Koyo bearings?
23 Nov 2023 14:18 #156
Just go to eBay and put in All Balls 24-1073
  All balls is the company that puts the kit together
​​​​​​   It says for IT 175 but that kit has the dual lip seals I hope I answered your question
23 Nov 2023 17:14 #157
Last edit: 23 Nov 2023 18:18 by Ht1kid.
23 Nov 2023 18:13 #158
  • torqueflight
When I look up the number for my bike it says 24-1072 is the right number. Woulnt 24-1073 be incorrect? Mine is a 74 dt125a.
23 Nov 2023 19:26 #159
Ht1kid already answered.  24-1073 has the better dual lip seal for the ignition side.
23 Nov 2023 21:42 #160
