1974 Dt360 where to start
- Mothersbaugh
Replied by Mothersbaugh on topic 1974 Dt360 where to start
Sounds like you have covered all the bases with the carb. After that, I'm out, as I have no experience or knowledge on the 360/400 bikes. Other than routine stuff which would apply to all the bikes.
Good luck!
Good luck!
19 Apr 2021 06:44
#11
- msavitt
Replied by msavitt on topic 1974 Dt360 where to start
if you got compression, fuel and spark then you would aleady zipping past jealous neighbors
if you can keep it running as long as your squiring ether into her (unlubricated
) then this hack thinks your spark/timing is close enough, leading me to think you have a fuel issue.
I recently rebuilt card on my DT1E and missed lining up the "jet, needle jet" axial slot with the locating pin and had a siphoning issue until I fixed this. I had gas in the bowl but she wouldn't run unless chocked...just an idea
whatever you do change the brake shoes before going on a ride above 10 mph
19 Apr 2021 09:01
#12
- run103
Replied by run103 on topic 1974 Dt360 where to start
Have you had the mag cover off and had a look in there. Lots of times the mag area is full of effervesence and rirt and aluminum and it will damage the pulser permanently. This is your symptom misfiring backfiring and quitting totally when hot unexpectdly.
Doug
Doug
19 Apr 2021 09:57
#13
- run103
Check the pulser in the mag It must be 90 to 100 ohms or the ignition will be intermittent the green/white and red/white wires. if you get below 90 ohms here you will have a poor ignition on no ignition
Doug
Doug
19 Apr 2021 13:54
#14
- 1974dt360a
Replied by 1974dt360a on topic 1974 Dt360 where to start
How do I check the pulser?
my flywheel is super rusty too. How should I be cleaning it?
does this look super bad?
23 Apr 2021 14:21
#15
Replied by RT325 on topic 1974 Dt360 where to start
Looks like yu have two post going on this. If it runs on start fluid it does still sound like the carb is blocked. If its got that side main jet in the bowl then it all starts from there. Does it suck if you put your hand over the carb with throttle open. Choke jet in the cavity in the bowl is prone to blockage, then if you open the choke it give more air making a bad situation eve worse if no fuel added from the fixed jet down the cavity.
23 Apr 2021 15:13
#16
- 1974dt360a
As previously stated, the carb is basically brand new. Yes the engine creates vacuum
23 Apr 2021 15:38
#17
