DT250 Exhaust Stud
  • peteyam54
  • peteyam54's Avatar Topic Author
DT250 Exhaust Stud was created by peteyam54
One of the studs that holds the exhaust to the barrel/jug on my DT250A has sheered. The part (39214-6510000) seems to be unavailable - from the parts diagram it looks like M6 on one end and M8 on the other, but I don't know the respective thread pitch or length. Does anybody have one they could measure or sell if spare? Thanks
13 Apr 2021 08:09 #1
Replied by mdscott on topic DT250 Exhaust Stud
I had the same broken stud, I ended drilling and removing the 6mm piece in the cylinder, drilled and tap to a 8mm stud with a heli-coil.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
The following user(s) Liked this Post: Rick C., Pedalcrazy
13 Apr 2021 08:14 #2
Here are pics.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
13 Apr 2021 08:16 #3
Replied by Gr8uncleal on topic DT250 Exhaust Stud
+1
Might not even need a helicoil, just put a 8mm tap through it.
Pitch is likely to be standard.
13 Apr 2021 08:18 #4
Probably right not needing the heli-coil, I like to overkill stuff, lol. I happened to have the heli-coils in my tool box.
I didn't realize the part in the head was a 6mm stud, so when I tightened the 8mm nut to the tightness I always have it snapped.
I've been a mechanic all my life so you have a feel of bolt tightness.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
13 Apr 2021 08:28 #5
Replied by MarkT on topic DT250 Exhaust Stud
Air cooled VW's used the 6mm/8mm stepped stud for repairs...  I think you can still find them.  I will look later
6 x 1.0 and 8 x 1.25
13 Apr 2021 10:28 #6
Replied by RT325 on topic DT250 Exhaust Stud
That was one of Yamaha's bad moves running 6 in the cylinder with an 8 to pull the exhaust up tight. Make you wonder what they were thinking that day. Probably told the apprentice in the cylinder machine shop at the factory to make them 8 stepped down to 6 but he got it reversed.
The following user(s) Liked this Post: Yamadude
13 Apr 2021 13:46 #7
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=123327009133&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • peteyam54
Replied by peteyam54 on topic DT250 Exhaust Stud
Thanks for all the replies and helpful suggestions. I've managed to find a couple of long stepped studs that will need cutting down, but should do the job. If that fails, I'll tap an 8mm in.
Not one of Yamaha's best designs! Cheers
14 Apr 2021 04:34 #9
Replied by ldw72120 on topic DT250 Exhaust Stud
Ace Hardware had them locally in their metric stud drawers.  No, I can;t imagine why.
18 Apr 2021 11:16 #10
