!975 Yamaha DT125B 12 volt brush replacement
- Patroll330
!975 Yamaha DT125B 12 volt brush replacement was created by Patroll330
I finally got my 1975 Yamaha DT125B up and running nicely next I want to replace my generator brushes. And help is appreciated .
- pabdt
Replied by pabdt on topic !975 Yamaha DT125B 12 volt brush replacement
be GENTLE w/the springs that hold them in and I would suggest the following:
clean the armature with fine sandpaper or emery cloth and the housing with a spray cleaner. make sure all the connections are clean/secure.
I used Oreilly's chemtool b-12 to spray the housing off and clean it.
Also, look at the brushes. If they are not close to the wear marker (an engraved line in the brush), I would gentely wipe the end of them w/sandpaper (to allow reseat) and put them back in.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Replied by MarkT on topic !975 Yamaha DT125B 12 volt brush replacement
If it's Berryman's B-12... that's a pretty potent carburetor cleaner. Nasty stuff. I'd be careful with it near electrical insulation and plastics.
The following user(s) Liked this Post: Patroll330
30 Mar 2021 19:47
- Patroll330
Replied by Patroll330 on topic !975 Yamaha DT125B 12 volt brush replacement
I cleaned the area up where the points and brushes are just need advice from there. Do you remove the cover that the brushes are stored in or remove them one by one until they are all replaced. Need all advice on brush replacement.
31 Mar 2021 13:05
A picture might be helpful... and there are lots of manuals in the Tech Library...
Anyway, from memory you don't remove anything. Just carefully pull the spring up and move it to the side and slide the old brush out. Slide new one in move spring back over to hold it.
The following user(s) Liked this Post: apex, 2fishkev, Patroll330
31 Mar 2021 18:28
