DT400B - Carb - washers & ‘o’ rings
  • Jammyyammy
  • Jammyyammy's Avatar Topic Author
DT400B - Carb - washers & ‘o’ rings was created by Jammyyammy
Hi all - I've taken the carb apart on my DT400B, to give it a good clean.
Can anyone recommend a uk seller for the 'o' rings and washers (I've already got the float chamber gasket) to use when rebuilding it...
I can only seem to find 'o' ring and washer kits for the DT400MX.
Many thanks....
14 Mar 2021 13:10 #1
Replied by Makotosun on topic DT400B - Carb - washers & ‘o’ rings
I am not aware of a current "kit" for those carbs. If you go to the Yamaha parts sites, most of the rubber stuff in the carbs is still available I believe. If not, check with SUDCO who is a major Mikuni parts stocker. The carb is a Mikuni, and all of the various bits should be available there.
14 Mar 2021 18:19 #2
Replied by Gr8uncleal on topic DT400B - Carb - washers & ‘o’ rings
+1
Parts should still be available from Yamaha.
In the UK, companies called Allens and Motocarb ring a bell as Mikuni suppliers, or just go to your local dealer or Fowlers online for them through Yamaha.
15 Mar 2021 01:11 #3
