Stand/Lift
- Jammyyammy
Stand/Lift was created by Jammyyammy
Hi all - I need to change the rear brake shoes on my DT400B. Will this style of stand/lift be suitable to get the back wheel off the ground? Thanks....
07 Mar 2021 23:09
- mdscott
Replied by mdscott on topic Stand/Lift
Lift your bike it would.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
The following user(s) Liked this Post: Yamadude, Andy L
08 Mar 2021 08:35
- Grussell
Replied by Grussell on topic Stand/Lift
I have one like that and it works fine. I can adjust the pad up or down with an allen wrench so I can use it on several different bikes. All you need is the rear wheel off the ground.
1978 DT400
1975 DT250
1976 YZ125X - my post vintage race bike
2022 KTM 300XCW - my race bike
1975 DT250
08 Mar 2021 14:22
Replied by MarkT on topic Stand/Lift
I have a cheap harbor freight one that looks somewhat like that but is useless to lift the bike without two people... and someone needs to keep standing on the pedal while a safety pin is installed or it un-latches itself half the time.
The quality ones work good.
08 Mar 2021 15:12
- Rick C.
Replied by Rick C. on topic Stand/Lift
Wanna go cheap? 5 gallon bucket turned over.
Hey, We all have done it.
The following user(s) Liked this Post: Bigdog302, Yamadude
08 Mar 2021 23:12
- Jammyyammy
Replied by Jammyyammy on topic Stand/Lift
Most lifts don't go down far enough - the DT400 only has 220mm clearance. Bought one of these in the end...
09 Mar 2021 03:56
- Schu
Replied by Schu on topic Stand/Lift
Keep an eye on the little thrust washer for the lead screw. It has tiny ball bearings that fall out if it wasn't assembled and roll pinned with proper preload. I kept finding little steel balls on my garage floor and ended up noticing they came from that thrust washer. I had saved them, so I punched out the roll pin and added a standard washer to increase the preload and reassembled it with all the bearings. Been working great ever since. It resides on top of my lift table for raising the rear wheel while it is on the table.
09 Mar 2021 15:54
- 1971DT250
Replied by 1971DT250 on topic Stand/Lift
This is what I have. Its sold by many different vendors.
www.harborfreight.com/1500-lb-aluminum-a...4EAQYCSABEgJmHPD_BwE
09 Mar 2021 17:32
That looks pretty awesome!
09 Mar 2021 19:33
- Jammyyammy
Thanks for all your responses/tips...
10 Mar 2021 01:52
