'74 360DT Was Converted to Points! Questions.
Replied by MarkT on topic '74 360DT Was Converted to Points! Questions.
If that flywheel clears the case, you should be okay.
You have the earlier RT/DT ignition system. I'm now curious about what bike you might have since I think you had a battery fitment problem too? Are you sure it isn't an RT3? Can you post a picture of the bike?
P.S. Not a CT stator... they had 2 holes, not 3.
04 Mar 2021 12:08
#11
- DBrew
Replied by DBrew on topic '74 360DT Was Converted to Points! Questions.
Hi. just joined. My 74 DT 360 has always had points(15 yrs since I’ve owned it) I thought maybe the early ones had points? Maybe it’s a conversion I didn’t know about? Getting ready to bring in from shed to “get back to it” after a few years. Thanks guys( it’s always run fine)
04 Mar 2021 17:05
#12
- warmblood58
Replied by warmblood58 on topic '74 360DT Was Converted to Points! Questions.
Bike is pretty stripped but the three digits (446) on serial number identifies it as a DT3 bike from 1974 DT360A. My battery well is tiny but the correct Yuasa fit fine -
- warmblood58
Interesting - I just assumed the 74 360 bikes all had the CDI setup
All 1974 DT360's did have CDI from the factory. Many people have swapped to the 74-on DT250 points system to get away from a non-working and expensive to fix (if it can be fixed) original CDI.
The following user(s) Liked this Post: nhsteve, warmblood58
04 Mar 2021 18:54
#15
I'm surprised you have the earlier RT3-type points setup in a DT360 engine. All reports I've seen say that flywheel OD or inside of case needs machining for clearance. Since you haven't posted relevant pictures of engine and OD of flywheel it's hard to say what has been done.
But if it fits, you should be fine. Clean the points good, set the timing correctly, and it should run great for many, many years.
04 Mar 2021 19:04
#16
P.S. Should be six magnets inside that flywheel for the three coil stator.
04 Mar 2021 19:05
#17
- Bill Black
Replied by Bill Black on topic '74 360DT Was Converted to Points! Questions.
I fitted a DT250 points system to my 360 only change needed was to machine a step on outer edge of flywheel near to crankcase as the six studs for tthe barrel make this a necessary modification ......
Regards
Bill
Regards
Bill
Bill Black
05 Mar 2021 04:47
#18
Bill, do you remember what year your ignition came from? Does it have the three coils on the stator or just two? Thanks.
05 Mar 2021 06:31
#19
Replied by Gr8uncleal on topic '74 360DT Was Converted to Points! Questions.
A slight wiring change will also be needed - DEET sells a "plug in and play" connection.
The following user(s) Liked this Post: 2strokenewb
05 Mar 2021 07:16
#20
