ROTORS , FOTO1971 VS F1T350.
  • Jewelkutter
  • Jewelkutter's Avatar Topic Author
Replied by Jewelkutter on topic ROTORS , FOTO1971 VS F1T350.
Hello everyone,
I have the dust cover against the seal now thanks again for the help. Just wondering if I don't have the bearing and seal in far enough because when I look at the lug on the lower fork engaging the brake plate it's not seated fully and the tire doesn't look quite perfectly centered on the fork brace , any thoughts greatly appreciated as always.
Last edit: 26 Jul 2022 16:38 by Jewelkutter. Reason: I did the double thing again sorry
26 Jul 2022 16:33 #21
Replied by AirborneSilva on topic ROTORS , FOTO1971 VS F1T350.
I'm thinking that if you loosen up the two nuts on the bottom of the right fork you should be able to get the axle in all the way then you'll be able to work the brake arm in some more.  Those two nuts are the last thing I tighten.
EDIT:  The brake arm bolt should ride in the grove, it can be a pain to work the arm onto the other side but it will go.
Last edit: 26 Jul 2022 16:51 by AirborneSilva.
26 Jul 2022 16:49 #22
  • Jewelkutter
Thanks for the info , will give it another go tomorrow after work
26 Jul 2022 17:18 #23
  • Jewelkutter
The 1975 Dt250 FOTO1971 Rotor, the one without the machined edge , fit my 1974 dt250 model ,has no clearance issues and is working great.
31 May 2023 18:16 #24
