Flywheel puller for a '74 DT 360 -Can Someone Direct me to the Right Size?
  • warmblood58
  • warmblood58's Avatar Topic Author
And now going to pull the magneto . . . clean up and replace that seal. Amazon fine for this, but need to get the correct size -anyone know? Thanks!
18 Feb 2021 07:23 #1
Motion Pro 08-0026 puller
The following user(s) Liked this Post: 2strokenewb
18 Feb 2021 07:43 #2
I think its a 27mm left hand thread
got mine for $10 on eBay, many on Amazon too
Clean out threads in flywheel really good with WD40 and to fully thread puller into flywheel because if yours is like mine the first time it was probably pulled since it left Japan took some real torque.
I like to use impact wrench on large nuts like flywheel, clutch, sprocket, but when i reassemble i make sure the threads and nuts are perfect - and chase if not - oil up and tighten with a torque wrench as these threads are very easy to tear up when tightening with impact wrench
18 Feb 2021 07:49 #3
  • warmblood58
Thanks so much, great advice!
18 Feb 2021 08:11 #4
I mentioned a specific quality puller because the market is flooded with cheap ones...
They are only a bargain unless you happen to get a poor quality one where the puller threads fail and destroy the flywheel threads in the process.  Then you'll wish you spent $5 more and got a known quality one.
Don't ask me how I know.
The following user(s) Liked this Post: msavitt, warmblood58, 2strokenewb
18 Feb 2021 09:33 #5
