bare tank
- DT125a
bare tank was created by DT125a
I had my tank go thru a dip at the local radiator company. All the paint...mainly...is gone and the inside of the tank is clean again. No more liner. Sitting in my garage its getting a little layer of rust on the outside. I'd like to put something on it to put a stop to that. Primer? Acid etching primer? Something rattle can would be easiest.
Do I put another liner in it? I don't know if it has any holes in it yet.
Ideas?
vic
Ideas?
vic
03 Feb 2021 18:25
- HouseofEnduro
Replied by HouseofEnduro on topic bare tank
Self etching primer from a spray can works quite well, I'd scour the outside to remove the flash rust and spray it asap. The inside has some pretty deep pitting, I'd line it just to be safe, and to prevent rust reoccurance.
03 Feb 2021 19:17
- apex
- Content Contributor
Replied by apex on topic bare tank
Agree with HOE with a primer outside. For the inside, everyone has an opinion and I'm not a fan of liners, at all. Why not mix up a batch of premix for testing purposes, install a petcock and a cap, put your premix in and see if it leaks? Gas will find the tiniest of holes, and it's easy enough to dump back into your gas can should you find it's got some pinholes you can't see or seams that are compromised. Those I would have properly repaired by brazing and go forth with an unlined tank.
Allrighty Then
The following user(s) Liked this Post: dwil4, yamahahaha, nhsteve, Pedalcrazy
- Bartman512
Replied by Bartman512 on topic bare tank
Please dont put liner in that beautiful tank
04 Feb 2021 05:17
- Quartermaster35
Replied by Quartermaster35 on topic bare tank
I filled my tank up 1/4 full with 2 stroke oil and shook it to coat the inside (while I work on finishing the outside of the tank etc).
The 2 stroke oil is "sticky" and protects the inside of the tank really well..
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
The following user(s) Liked this Post: dwil4, LETSJET
04 Feb 2021 05:28
- AirborneSilva
Replied by AirborneSilva on topic bare tank
I would use an epoxy based primer as regular rattle can primer absorbes moisture.
Curious as to why some of you wouldn't put a liner in the tank. My tank doesn't have much rust, that I can see, but thought I'd line it just to be safe and keep any future rust from happening.
04 Feb 2021 10:31
- nhsteve
Replied by nhsteve on topic bare tank
Good point on the epoxy primer.
Regarding liners, all I can say is that be sure that the inside is really, really, REALY clean. I did a 2-part epoxy liner that I mixed exactly per directions, and within 2 years it was lifting in sheets inside the tank. Very disappointing. I suspect it was because I did not get it clean enough, although I certainly thought I had done a good job at the time. I think it is like getting a good result on a paint job. The 3 most important things to get right are preparation, preparation, & preparation. Something like acetone as a last rinse maybe. You get the idea.
04 Feb 2021 13:37
Replied by MarkT on topic bare tank
Lining is a bad idea unless needed because they fail a lot and it's a nightmare when they do. Ethanol in the gas is especially hard on the liner.
That said, I used POR15 on my MG1T tank because it had pinholes. Sealed it well and has been holding for maybe 10 years now. There are other sealers that people have had good success with... and prep is definitely important... I followed the POR15 directions exactly and used their prep solutions and rinses.
04 Feb 2021 13:45
- AirborneSilva
Thanks for the advice on the liners.
04 Feb 2021 14:13
