76 DT400 parts bike for 74 DT250 project
  • mikeinkent
  • mikeinkent's Avatar Topic Author
76 DT400 parts bike for 74 DT250 project was created by mikeinkent
Local Craigslist ad for 1976 DT400 for parts, for $200 firm! Oil tank, front and rear wheels, tank, front fender and engine with no cylinder, piston or carb, .
I have a 74 DT250, my question is does the lower engine share parts do the wheels work with my model? I'searchedthe forums for days now, but can't find a definitive answer for interchangability of parts. Anybody got some wisdom for me?
02 Feb 2021 00:39 #1
Replied by Makotosun on topic 76 DT400 parts bike for 74 DT250 project
The wheels should be a direct interchange. Same with forks, oil tank, most frame parts.
02 Feb 2021 07:24 #2
Replied by MarkT on topic 76 DT400 parts bike for 74 DT250 project
Center cases and crankshaft will be different.  Other internal engine parts are likely to work.  Best thing to do is compare the parts list for your 74 with the one for the 76.
02 Feb 2021 07:33 #3
Agreed. The motors have some interchangeable bits, bit the frame and running gear are mostly interchangeable.
02 Feb 2021 07:35 #4
  • mikeinkent
Replied by mikeinkent on topic 76 DT400 parts bike for 74 DT250 project
Thanks for the info! I'll go to the bank, get some Yamadollars, hunt the bike down and bag it and tag it!
02 Feb 2021 11:56 #5
Replied by Lizeec on topic 76 DT400 parts bike for 74 DT250 project
02 Feb 2021 20:51 #6
Replied by run103 on topic 76 DT400 parts bike for 74 DT250 project
with a little luck you might get a 6 volt regulator in the deal and that will be good for your 250.  The engine will fit either frame has been my experience.
Doug
03 Feb 2021 13:14 #7
I stand corrected on the front wheel, though I believe the later wheel will fit. Same axle, so that’s not an issue. I have fit a 19“ front full hub wheel on a 75, so it should work fine.
03 Feb 2021 22:19 #8
