Is Primary drive gear left hand thread?
- AirborneSilva
Is Primary drive gear left hand thread? was created by AirborneSilva
Hey guys, after watching a couple of videos on replacing cranck seal they all said the primary drive gear is left hand thread but looking in the service manual they don't mention it at all, so, on my 76 DT400 is that also a left hand thread? Thank you, Tony
01 Feb 2021 02:29
Replied by RT325 on topic Is Primary drive gear left hand thread?
Nope, just normal RH thread. Lefty loosey Righty Tighty directions.
- AirborneSilva
Replied by AirborneSilva on topic Is Primary drive gear left hand thread?
Thank you! I didn't want to be tightening it and screw it up thinking I was taking it off.
01 Feb 2021 03:50
- bosco659
Replied by bosco659 on topic Is Primary drive gear left hand thread?
Any tips or tricks to hold the shaft while removing the nut?
01 Feb 2021 03:51
- AirborneSilva
The shop manual says to fold a rag several times then wedge it between the gears, I figured I'd give that a try, wish me luck
01 Feb 2021 03:55
I just trap a piece of alloy in between the gears. Just a piece of old number plate--registration plate in my case. If you had a half inch drive rattle gun & whatever size '30mm i think' socket it'll probably come off just holding the clutch basket by hand to put a bit of resistance on it. Just my ideas.
01 Feb 2021 03:58
- bosco659
Ok thanks for the ideas. If holding the clutch basket I’d wear a heavy pair of gloves as the gear reduction delivers quite a bit of torque to the basket.
01 Feb 2021 04:57
- Pete-RT1
Replied by Pete-RT1 on topic Is Primary drive gear left hand thread?
Yamaha CT3 (in bits)
