DT400b - speedo light...
  • Jammyyammy
  • Jammyyammy's Avatar Topic Author
DT400b - speedo light... was created by Jammyyammy
Hi all - my DT400B is missing the bulb holder complete with rubber bung and cable/wiring tails (that presumably connects to the wiring inside the headlight) for the speedometer. Does anyone know if this part is specific to the DT400B? Will a part from another bike fit? Will an aftermarket part fit? - Failing that, all I can do is wait for a used one to come up on eBay... Thanks all. Phil
29 Jan 2021 09:22 #1
Replied by Gr8uncleal on topic DT400b - speedo light...
As long as the rubber bulb holder matches the size of the hole in the speedo, then more or less anything can be used, from any manufacturer.
Standard Yamaha wire colours would be black and blue and I am attaching the image from CMSNL.
I think that I have seen generic ones on the Yambits site here in the UK, or you could make up your own. Obviously make sure that the wires are long enough! :EEEK :ROFLOL If you get stuck (and you're in the UK), I've probably got enough spare parts to put one together.
www.cmsnl.com/yamaha-dt360-1974-usa_mode...353630/#.YBRJxUNxdaQ
Last edit: 29 Jan 2021 09:55 by Gr8uncleal.
29 Jan 2021 09:54 #2
Replied by AirborneSilva on topic DT400b - speedo light...
Here's one for a 76 DT400 but should work for you.
Speedometer light
29 Jan 2021 11:26 #3
