1974 DT175A
- motovate
1974 DT175A was created by motovate
Starting to get to the To Do list on my 1973 DT175. Verified the vin with the USA Model Listing. The bike came with a plastic after market fuel tank so I'm not real sure what came with it new. Somewhere along the way I picked up a pretty good blue/white stock tank - pretty sure it is a 73A but could be a 74B. I'll need to do some searching to see if it is Yale Blue or a Balboa Blue tank needs de rusted inside as usual. I had a tank gas cap - that went on a sojourn - somewhere. I was wondering if there was a source for stock type aftermarket gas caps or other models/brands that will fit these tanks. I found a couple NOS on Partzilla and Bike bandit but $70 to 90+ dollars is not much interesting. I'm not restoring to original just getting it running good and looking decent. I'm sure as I get back into it I will have some questions. It did run OK when I got it- sorta didn't want to idle until good and warm - clean the carb type thing, tail light issues but fixed and never replaced on bike and headlight was a replacement but with a little paint it will be good, tires, all the normal things and whatever I find now. Figured I start with the cap and eBay. Thanks LBM
Replied by MarkT on topic 1974 DT175A
Probably would help to re-check the VIN... You've jumped around between describing it as a 73-74-75-76...
A 1974 "A" had a completely different paint scheme than the similarly painted 75 "B" or 76 "C". A and B tanks are the same shape with the A model having the hinged "flip top" cap and B having a removable twist off cap.
1976 C models had a different frame and different tank shape and tank mounting than the A and B.
So technically every year from 74-76 had a distinctively different tank... though an A tank will fit a B frame and vice-versa. 1976 C model tank only fits 1976.
I'm pretty sure the early non-locking cap fits the 75-76 locking cap models. I don't have a tank handy to check.
P.S. the above applies to US models.
- motovate
Replied by motovate on topic 1974 DT175A
Thanks - I did get myself confused on the 1973 model year. It is a 1974 which makes it a "A" on the Vin as far as the title says and by looking @ the USA List here. The Vin is 443008198. I did describe the used tank as possibly a 73A or74 B but I wasn't sure - pretty sure it is not a 73 anything. I do realize there are different paint schemes. The tank I have is the one I like. I probably should have describe it better the tank is blue and the graphics on the side are a white panel with the middle 1/3 as a Black section with 175 on it and as I remember the cap was twist off - tabs on the cap that go through notches in the tank but not screwed on or off. I looked on line but it is really crossed up. I saw supposed DT 175's as 74's with the same blue tank as I have , in Red & different blues, & a 1976 with the same graphics as this one - pretty sure they are even more confused then I am . One of these days I'll dig out my digital camera and take a few shots and down load them here to be sure. I'm going to keep looking for the one I had - it's hidden there somewhere.
22 Jan 2021 20:49
1975 and 1976 had a very similar paint scheme that you've described. If the tank you have fits the 74 frame, it's a 75 tank.
69-71 CT1 cap reportedly fits the 75-76 tanks and is a lot cheaper.
22 Jan 2021 21:10
- motovate
Well Knowing 75 & 76's had similar paint schemes is good to know. I like the tank & it only has a couple of small dings. I'll probably just wash it good and maybe polish it a bit and clean the inside out good. At least at the time I bought it I was sure it would fit. The plastic desert tank is pretty ugly but holds gas. Thanks.
23 Jan 2021 04:04
