1975 DT250 Looking for correct ignition coil
  • arch75250
  • arch75250's Avatar Topic Author
I need to purchase a new ignition coil for my project bike. The one that came on it had a very crispy spark plug lead which snapped when I was moving things around.
There are two different part numbers listed for the coil in the parts diagram. Does anyone have any guidance on which one I should search for? Speed and Sport Inc. has both listed as available, one is quite a bit more expensive than the other. I have the original but it doesn't have the Yamaha part number on it. It is stamped F6T409 and it looks like it was manufactured by Mitsubishi, or at least it has a similar logo.
The Speed and Sport parts numbers match the parts list numbers as follows:
5G4-82310-40-00 IGNITION COIL ASSEMBLY J17-823 email $116.55 (it may be that this part is used, it isn't really clear)
498-82310-40-00 IGNITION COIL ASSEMBLY $186.45
I see the 498 one available on ebay for $80 but it simultaneously says it's new and being sold "as-is" and hasn't been tested. The pic of it looks pretty used so I'm a bit hesitant. I had already purchased one from Partzilla but I screwed up and made an assumption on a part that looks right but had a different part number and it doesn't get the correct resistance readings. I'm a bit out of my element with the electrics. Any help would be greatly appreciated.
Thanks,
Mike
13 Jan 2021 15:32 #1
  • arch75250
Replied by arch75250 on topic 1975 DT250 Looking for correct ignition coil
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=283643843208&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by Swoop56 on topic 1975 DT250 Looking for correct ignition coil
498 ignition coil is the factory unit for the 250 .
The other option will be for the 400 , which has a CDI ignition , and a different output requirements .
The Ebay option might work , but is most definitely not a factory unit .
Some of the cheap Chinese units are a bit Hit or Miss .
13 Jan 2021 18:06 #3
Many have had new coils "test" fine but not have spark.
Mounting may need some fabricating but many... including myself... have had good luck with the Emgo universal coil 24-71532 on either the points or CDI models. Good strong spark.
13 Jan 2021 18:26 #4
  • arch75250
That looks pretty good and affordable. I can fabricate like a banshee but have a tough time understanding wiring. I did just pull the trigger on the expensive one with the correct part number from speed and sport but might cancel if you think the Emgo is a good option. My little $200 barn find is starting to get expensive! Thanks to both of you for the advice!
Mike
13 Jan 2021 18:46 #5
Replied by DaveHunter on topic 1975 DT250 Looking for correct ignition coil
Is your spark plug lead replaceable buddy? Sometimes they are threaded into the coil.
13 Jan 2021 18:47 #6
  • arch75250
Good question. I think I looked at it and thought it wasn’t replaceable but maybe I didn’t try to unscrew it. I did try to test it but wasn’t sure I was getting the right readings. Being a bit of a novice, especially with the electrics, my tactic has been to just replace with new, that which I don’t understand.
Probably not the best way to learn. If I can get the old one off, and if the coil tests okay, can I use any spark plug wire or is there anything specific I need to get?
13 Jan 2021 18:58 #7
  • arch75250
Another related question, is it common for the spark plug cap to go bad? I tested it with a test light and it passes current but dimly. Is that something that has a resistance rating I need to check?
13 Jan 2021 19:26 #8
I am not familiar with your model & only asked as that is the case sometimes. The local auto part store here sells it by the foot for those wanting to make up their own cables
The following user(s) Liked this Post: arch75250
13 Jan 2021 19:26 #9
You need copper core spark plug wire and yes the cap is a resistor cap.
13 Jan 2021 19:50 #10
