Life after meltdown
Replied by Pete-RT1 on topic Life after meltdown
Msavitt did you mean Allen Millyard?
He certainly is a genius, some of his projects are are amazing.
www.youtube.com/user/millyardviper/videos
Yamaha CT3 (in bits)
18 Jan 2021 01:11 #31
  • msavitt
  • msavitt's Avatar Topic Author
Replied by msavitt on topic Life after meltdown
yes - that's him, he's insanely creative and incredible with a file!
I have another question; specifically the roller bearing on the clutch side of the output shaft has a a bull-nose on the inner race. Does bullnose face the idler gear, or the inside of the transmission? I am leaving nothing to chance this time around, Santiago Peak is calling my name!
18 Jan 2021 09:40 #32
Replied by Jack on topic Life after meltdown
Good question and I asked the same one when putting mine together. I looked everywhere I could think to look and never did find a definitive answer. Someone said it probably didn't make any difference in this particular instance and I think that's probably correct. With no way of knowing for sure I had to eventually make a best guess and I chose to put it in with the beveled end facing to the outside. I'm not saying that's correct and it's a worry. Hope someone chimes in before you put your case halves together. If not it's a coin toss.....
18 Jan 2021 15:19 #33
  • msavitt
thanks for response
either way this end floats between same size circlip so if I was a circlip I don't thing it would matter.
I am going bullnose out cause it looks nicer
18 Jan 2021 15:32 #34
  • msavitt
Jack, others - did your tach drive have the spacer shown on Partzilla that sits between top of plastic tach gear and clutch cover?
Mine did not and measurements with washer and gear installed as I removed leaves 0.016" (ignoring gasket) between plastic gear and clutch cover, so no way. I am thinking it's for DT250??? only a very think thrust washer could fit and one didn't come out.
18 Jan 2021 16:01 #35
I haven't got that far. Haven't touched the engine since I put the case halves together. Shop is like an ice box right now and I'm waiting for warmer weather. I don't think that spacer you're talking about was on there, at least I don't remember seeing it if it was. It'll be in with my parts if it was and will look through them tomorrow and see if one's in there. But if there isn't room for it then I wouldn't worry about it. If it won't fit, it doesn't belong there.
18 Jan 2021 18:14 #36
  • msavitt
thanks
I left Chicago 6 years ago for S CA after 49 years of freezing my ass off. My last cold garage memory was working on my Bug when a case of beer bottles popped their caps all at once.
thanks agan
18 Jan 2021 18:35 #37
Spent three years in near Santa Ana (69-72) and I start missing it about this time every year.
18 Jan 2021 18:46 #38
No spacer in my parts and after taking a look at my engine it's just like you said, there's not any room for one on that shaft anyway.
19 Jan 2021 11:23 #39
You got me thinking there as I've just put my CT1-C back together which does have a spacer, anyway you guys are dead right, the spacer is for the 250.
You're not the only one to have gone through this, here's the investigation work done by others.
www.yamaha-enduros.com/index.php/forums/...ter-gear-dt360#93003
The following user(s) Liked this Post: MarkT, Snglsmkr, msavitt, Jack
Last edit: 19 Jan 2021 12:16 by Pete-RT1.
19 Jan 2021 12:13 #40
