So much for “running perfect”
  • msavitt
  • msavitt's Avatar Topic Author
So much for “running perfect” was created by msavitt
My ‘74 360 was 100%, or so I thought after venturing out on longer and longer rides without issue.
Today after replacing brake shoes - based on horror stories about separating linings and riders - I took a hot lap around my town on my detonation 360 and at around 55 mph in 4th / 5,500 rpms it just died. Pushed this pig in bike pants about 1/2 mile until neighbors kid in raptor took me last mile.
Took plug out and found it to be nicely sprayed with what appears to aluminum deposits. I will pull apart tomorrow but suspect I burnt a hole in piston.
How could this be if oil pump, timing, carb set right? Will post what I find with the goal of learning what happened to prevent a reoccurrence.
Ho HO Ho merry Christmas!
24 Dec 2020 17:20 #1
Replied by Snglsmkr on topic So much for “running perfect”
Ugh!
24 Dec 2020 17:59 #2
Replied by MarkT on topic So much for “running perfect”
If you can pressure/vacuum test before taking apart it would be a good idea.
24 Dec 2020 18:16 #3
Replied by turbodan on topic So much for “running perfect”
My condolences. That is ugly. With a little luck a fresh bore and new top end will be all it needs.
As far as remediating the root cause, I think you know what I would recommend...
24 Dec 2020 18:47 #4
  • msavitt
Replied by msavitt on topic So much for “running perfect”
Tdan - Stuff her ?
24 Dec 2020 21:48 #5
Replied by Enduro nut on topic So much for “running perfect”
My best guess would be running too hot of a spark plug? That is assuming everything else is working as it should.
24 Dec 2020 21:54 #6
Replied by RT325 on topic So much for “running perfect”
Comiserations & can't realy guess at the cause except keep them plenty rich on needle & main. Leaking mag crank seal is unlikely as are robust unless its popped out on an angle just. Keep the timing well back, like 12thou. I feel for ya though & been there before. Typing on my useless phone & cant see the heading thinking yours is an RT before '74, if after it'll be a cdi mag of course.
25 Dec 2020 00:45 #7
Replied by 1971DT250 on topic So much for “running perfect”
The '74 360 has a reputation of burning a hole through the top of the piston. It was mentioned in old magazine articles as well as recent experiences like yours. The parts diagram lists the standard main jet for the '74 as being a #140 with optional up to #190. The '73 is a #230 for standard. I run a #240 in my RT3 regular riders. And I avoid long sustained runs at high speed. Yamaha may have leaned out the '74 for emissions reductions back in the day.
Last edit: 25 Dec 2020 06:16 by 1971DT250.
25 Dec 2020 06:12 #8
Indeed. You'll be in there, might as well.
25 Dec 2020 08:03 #9
Replied by Pedalcrazy on topic So much for “running perfect”
Dang that sucks. The DT360A is a bike on my bucket list but with all I've read here abouts I'm not sure now. My DT400 has a little detonation going on and It's been 1200 miles since a COMPLETE engine build so while waiting for my sleeper pipe this summer I pulled the head to de-carbon. I was pleasantly surprised that the top of the piston and head look like new after some cleaning. Apparently they'll take some detonation without damage. The 360 must really knock. I here a temp gauge is not fool proof but I use the Trailtech TTO 14mm temp gauge and watch head temp while riding. Vary activities if temp starts getting high. Good luck with your rebuild. I'm sure you'll post pics of teardown?
25 Dec 2020 16:16 #10
