75 Dt400b battery (eliminator)
  • greens8
  • greens8's Avatar Topic Author
75 Dt400b battery (eliminator) was created by greens8
Hi, I ended up installing a Rex`s speed shop 12v ignition. After initial problems, it was delivered to the wrong address, the three threads for mounting the stator were butchered with the most amateur installation of helicoils ever, I have it installed and was pretty impressed by the wiring being matched to the original harness, didn't need to bodge any connectors at all, I am ready to start up. It has new top end and oil pump, pretty keen to get it going but I didn't realise when I bought a battery eliminator locally that Rex`s have in the small print a warning that you need their exact eliminator. I cannot find a battery to fit the tiny space. I have now ordered the Rex eliminator but it takes so frickin long to ship here I am going to be sorely tempted to start it with the eliminator I have. What are your thoughts on this?
22 Dec 2020 00:29 #1
Replied by RT325 on topic 75 Dt400b battery (eliminator)
I'm totaly guessing here, but i 'guess' that if you 'don't run the lights' or better still don't even connect them then i can't see a problem. Just have the CDI hooked up to run the motor & leave the rest. Now only knowing what i've read on here does yours have a keyway in the flywheel or do you need to time it & do that damn nut up 'super tight' with an undamaged crank taper?. Gotta be tight regardless of key or no key of course. Look forward to hearing good results & prepaired to be shot down in flames if i'm steering you wrong.
22 Dec 2020 02:58 #2
Replied by AirborneSilva on topic 75 Dt400b battery (eliminator)
Did you ever get the battery eliminator? I have a 76 DT400 that I just did a 12 volt conversion on and like you I too am having issues finding a battery to fit. I was thinking of going with Rex's eliminator too so I'm curious to hear how it worked out for you. Thanks, Tony
17 Jan 2021 09:23 #3
Replied by MarkT on topic 75 Dt400b battery (eliminator)
Here's what mdscott did for a battery with his DT360... pretty sure same battery box as 75/76 DT400
yamaha-enduros.com/index.php/forums/gene...0-12v-battery#107295
17 Jan 2021 09:40 #4
Replied by Wessi on topic 75 Dt400b battery (eliminator)
Hi all,
i bought a YTR4A-BS Battery, which has usually 2.3 AH.
Same widht and lenghth as the 6V stock battery, but a few Millimeters less in height.
Couldn“t find any better...
The following user(s) Liked this Post: MarkT, JayB
17 Jan 2021 23:48 #5
