75 DT250 Front Signal Lights
- Kip
75 DT250 Front Signal Lights was created by Kip
Removed my signal lights and tail light some time ago...like 1980s and working on reinstalling to bring it back to street legal. Since it was so long ago I don't recall and can obviously see where the single wire for the front signal lights connect. Appreciate any help with this. thx.
Replied by MarkT on topic 75 DT250 Front Signal Lights
Inside the headlight bucket... usually a couple "double" female bullet sockets, one brown and one green.
29 Nov 2020 13:25
I should have said Dark Green (right) and Dark Brown (left).
There are lighter brown and lighter green wires in the headlight bucket...
29 Nov 2020 16:36
Replied by Gr8uncleal on topic 75 DT250 Front Signal Lights
Probably three/four hole female, depending on how the feed is connected - one hole for each of indicator, switch and warning light.
As Mark said, make sure they are the darker brown and green - give the wires in there a rub with a cleaner, just to get the dirt off them and be able to see their true colours (the dark green can look black).
If the wires coming from the centres of your indicators are black, then connect the right one to the dark green female block and the left one to the dark brown female block, orientation taken as you're sitting on the bike.
30 Nov 2020 00:20
- Kip
Replied by Kip on topic 75 DT250 Front Signal Lights
Thanks MarkT and Gr8uncleal. Had removed the headlight and was wondering if this is where they connect. Much appreciated.
01 Dec 2020 08:37
