DT360 flasher
  • msavitt
  • msavitt's Avatar Topic Author
DT360 flasher was created by msavitt
anyone ever experience weirdness with a bad flasher?
wiring and switches seem in order, but only R works slowly
any recommendation on a replacement that's plug and play and not $150 appreciated too!
thanks!
13 Nov 2020 09:54 #1
Replied by Gr8uncleal on topic DT360 flasher
Assuming that it's not a bad earth/connection somewhere, then any modern 6v (assuming that you haven't converted to 12v!) two pin one should be fine.
Last edit: 13 Nov 2020 10:00 by Gr8uncleal.
13 Nov 2020 09:58 #2
Replied by Pedalcrazy on topic DT360 flasher
Those 6v systems are sensitive to using the correct and matched wattage bulbs. It could be as simple as the side that doesn't flash may have larger wattage bulbs or mismatched wattages. Front and rear need to be the same and correct wattage.
Last edit: 13 Nov 2020 15:33 by Pedalcrazy.
13 Nov 2020 15:32 #3
Replied by MarkT on topic DT360 flasher
The original flasher is sensitive to correct load. Most modern replacement 2 wire (not 3 wire!) 6v flashers are not.
Discussed here dozens and dozens of times so a forum search will provide a lot of info.
13 Nov 2020 15:49 #4
Replied by DaveinSC on topic DT360 flasher
I switched to a 12 volt vape system so you can have and try my old one if you want it.
13 Nov 2020 19:19 #5
Replied by nhsteve on topic DT360 flasher
I'm using a 2 prong flasher off eBay, along with new bulbs and cleaned up connections. So far so good. If I can find the receipt with the # I will post that up.
14 Nov 2020 08:20 #6
Seller Pobit on ebay sold one that was well-reviewed as working good. Came with connectors and instructions. Unfortunately it looks like his store is closed until the 21st.
14 Nov 2020 08:29 #7
