Need Input on Swingarm clearance
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic Need Input on Swingarm clearance
Notes:
The Service manual indicates 0.04" or 1mm for swing-arm left to right clearance.
Use a "SHIM" to decrease clearance. A shim is shown in the Yamaha parts source below.
Use a "SPACER" to increase clearance.
After powder coating my swing-arm and adding new bushings, I ended up with
Clearance = 0; This resulted from newer bushings that were slightly thicker and most of the clearance from the added thickness of the powder-coat.
I modified a steel "machine" washer from ACE Hardware that measured 13.02mm x 22.21 x 1.21mm and ended up with
21.90mm x 16mm x 1.21mm
The stock swing-arm bushing is 21.95 mm OD and the swing-arm bolt OD is about 15.80mm.
Clearance is slightly higher than spec, no movement detected, but the swing-arm moves freely.
After the bike has some miles on it, can revisit this clearance. assembly continues...
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
Last edit: 23 Oct 2020 12:45 by pabdt.
23 Oct 2020 12:41 #11
