Recommended replacement carburetor - 1975 DT175
  • denisj
  • denisj's Avatar Topic Author
Hi All
I am looking to replace the damaged carburetor on a 1975 Dt175.
I contacted Sudco, and they do not have a listing specific to that machine.
Has anyone installed a new Mikuni VM carburetor?
If so what size did you get and what jetting do you settle at?
Thank you so much for your help!
Denis J
05 Oct 2020 11:31 #1
Replied by Gr8uncleal on topic Recommended replacement carburetor - 1975 DT175
I'd probably search this site or fleabay for a decent used one. Certainly here in the UK they seem to be the ones that turn up most often.
06 Oct 2020 00:09 #2
Bone stock? VM24 (or equivalent knock-off.) Mine's been ported so I've got a modified 28mm flat-slide carb on for a bit of fun :) (The outer diameter of 24 & 28mm carbs are usually the same.) eBay/Chinesium copies are pot luck on quality.
06 Oct 2020 08:37 #3
