Dt 360 clutch seal replacement
  • treeves
  • treeves's Avatar Topic Author
Dt 360 clutch seal replacement was created by treeves
I am trying to replace the clutch seal on the bottom of the engine. I have loosen the adjusting nut and unscrewed the adjusting screw as far as it will unscrew but when I try to pull lever axle it moves a little but can not get out, sounds like it is hitting something. What else should I do?
13 Sep 2020 11:47 #1
Replied by msavitt on topic Dt 360 clutch seal replacement
Hi - I just did mine
you have to go kinda back and forth with the adjuster that has an offset pin while wiggling the clutch lever.
Same when you reinstall
13 Sep 2020 13:05 #2
Replied by Snglsmkr on topic Dt 360 clutch seal replacement
The offset pin on the adjuster that msavitt mentioned rides in this grove on the clutch actuator. If the adjuster is not backed out far enough the actuator will hang up on the adjuster pin.
Last edit: 13 Sep 2020 16:44 by Snglsmkr. Reason: Misspelled handle
13 Sep 2020 16:44 #3
  • treeves
Replied by treeves on topic Dt 360 clutch seal replacement
Thanks for the replys. I have backed the screw out as far as it will go and wiggled as screwing adjuster screw back in but still have not gotten the actuator out yet. Thanks for all the help, will try again tomorrow.
13 Sep 2020 17:26 #4
  • treeves
I had not backed the adjusting screw out far enough, after jiggling and working the adjustment screw it came out.
The following user(s) Liked this Post: MarkT, RT325, Gr8uncleal
14 Sep 2020 16:20 #5
