Shift countershaft stuck
  • RustiePyles
  • RustiePyles's Avatar Topic Author
Shift countershaft stuck was created by RustiePyles
I’ve been fighting this shift countershaft for quite a while, it’s rusted up pretty bad. I’ve tried PB Blaster, liquid Wrench, brake fluid & acetone, heat (map gas), currently have the cavity filled with Evapo-Rust. Anyone else fight this battle and win?
Fletch
1975 DT175B
1979 XS650
29 Aug 2020 09:51 #1
Replied by MarkT on topic Shift countershaft stuck
That design was not one of Yamaha's better ideas...
What are you trying to do?
29 Aug 2020 10:03 #2
  • RustiePyles
Replied by RustiePyles on topic Shift countershaft stuck
Trying to split the cases.
Fletch
1975 DT175B
1979 XS650
29 Aug 2020 10:05 #3
I'm sure I have nothing new to add but I use a large brass punch and tap the shaft with the arrow in pic below out after removing the clip and disengaging the "claw" from the shift drum on the other side of the engine.
The following user(s) Liked this Post: Supergraphic, RustiePyles
29 Aug 2020 10:21 #4
  • RustiePyles
Evapo-Rust did the trick.
Fletch
1975 DT175B
1979 XS650
The following user(s) Liked this Post: yamahahaha, Supergraphic
29 Aug 2020 11:21 #5
Replied by RT325 on topic Shift countershaft stuck
Yep, certainly not Yamaha's best idea & would last better if the seal was left out so the gearbox oil filled that area as well.
The following user(s) Liked this Post: RustiePyles
29 Aug 2020 14:31 #6
  • RustiePyles
I’m drilling and tapping the cover for a zerk.
Fletch
1975 DT175B
1979 XS650
29 Aug 2020 14:39 #7
Replied by Supergraphic on topic Shift countershaft stuck
How did you get the screws out? Mine seems stuck so I can't get that shift Shaft cover off...
been trying to use an impact driver to no avail.
16 Oct 2020 08:53 #8
  • RustiePyles
I didn't have any problems with those particular bolts, but I've had pretty good luck with PB Blaster, a little bit of heat from a propane torch, and an impact driver. Make sure your impact driver is driving the right direction, sometimes they can get reversed unbeknownst to the operator.
Fletch
1975 DT175B
1979 XS650
16 Oct 2020 10:13 #9
