Keihin 35mm PWK is a great fit on the DT360
Replied by mdscott on topic Keihin 35mm PWK is a great fit on the DT360
I found a solution for my DT360 throttle cable too long, may not be perfect but it worked. I had Venhill universal throttle cable kit and found a piece you would use to make a cable. Below is the picture, the spacing made it perfect. Now the carburetor cable is the correct length to operate the oil pump.
yamaha-enduros.com/index.php/forums/74-7...rottle-cable?start=0
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
21 Oct 2020 08:08 #21
Replied by crazyracer on topic Keihin 35mm PWK is a great fit on the DT360
Gracias gents. This clears up a number of questions I had.
Tangent question (if this is allowed, if not, I'll search elsewhere) - I'd like to do a similar carb swap on my 73' 250. It has the bolt-on carb currently. What intake manifold suits this carb that may line up with the D3 bolt pattern?
BTW I am new here to this site. Holy smokes what a treasure trove of fun information. I love it!
29 Oct 2020 08:38 #22
  • turbodan
Replied by turbodan on topic Keihin 35mm PWK is a great fit on the DT360
Hope this link works:
cdn6.bigcommerce.com/s-cdk22v/product_im...art.jpg?t=1434041747
One of those should be suitable.
29 Oct 2020 12:01 #23
Not all hero's wear capes.
You're the man.
29 Oct 2020 12:21 #24
Replied by nhsteve on topic Keihin 35mm PWK is a great fit on the DT360
Really good thread here guys, appreciate all the info. The Keihin carb looks a lot like the OKO carb I purchased for a TY250 (my thread is on here somewhere in the TY section). That seems to be running quite well so far.
May I ask where you obtained the carb, and bits? I got the TY setup from the Atlantic trials guys.
10 Nov 2020 06:08 #25
  • turbodan
Mine came from ebay.
10 Nov 2020 16:44 #26
  • turbodan
I figured it was worth updating this thread to mention that the non-notched slides work better in this application.  Both of the PWK35 slides I had were factory notched.  Both have been difficult to get to run as cleanly as I would like so I tried modifying both of them in different ways.  I found one recently without a notch and tried it out just for kicks.
The biggest difference is the improved idle characteristics.  Runs a more consistent speed from cold up to operating temp.  Allows a lower idle setting without stalling.  I was also able to lean out the needle clip position which has improved mid throttle fueling.  On a 250 or smaller you may benefit from the notch, I ran a notched slide on my piston port 250 with excellent results.  The PWK I set up for one of my 125 builds ran a notch as well.  I think the 360 draws strongly enough on the carb that the notch is not necessary or beneficial.
20 Feb 2021 14:36 #27
Would it be possible for you to please show pictures of the notched and un-notched slides?  I am not sure what you mean by a notch.
Thank you!
20 Feb 2021 16:31 #28
  • turbodan
Right in the center of the slide.
Keihin sells both versions.  My KX250 uses a notch, my bud's RM250 does not.  KX500 does not.
The following user(s) Liked this Post: MarkT, JayB, nhsteve, Jack
20 Feb 2021 17:30 #29
Thanks for the pictures Turbodan!
The following user(s) Liked this Post: turbodan
20 Feb 2021 18:46 #30
