Points cam stuck
  • RustiePyles
  • RustiePyles's Avatar Topic Author
Replied by RustiePyles on topic Points cam stuck
No worries, I understand what you mean. The amount of advance appears to only be about 2-4 degrees so the difference between retarded and advanced can be compensated with gap timing alone.
Fletch
1975 DT175B
1979 XS650
15 Aug 2020 18:57 #11
Replied by Midlife Motor on topic Points cam stuck
MarkT your replies made perfect sense. As the owner of a 76 DT175 it was perfectly clear to me what you were saying regarding putting cam in a fixed position. Your 7000 plus posts are a testament to your knowledge and level of helpfulness.
15 Aug 2020 19:14 #12
Replied by RT325 on topic Points cam stuck
Yep agree, because to get timing right with cam on retard i'd wildly guess you'd need a 40 thou gap.--or something not feasible. Can you slot the back plate a little & get away with it or would replacing countersunk screws with flat head screws or bolts rub on the flywheel.
Last edit: 16 Aug 2020 05:14 by RT325.
16 Aug 2020 05:08 #13
