1974 DT360A - voltage regulator installation
- msavitt
1974 DT360A - voltage regulator installation was created by msavitt
Hi All,
I just got done going thru my new ride end to end, she runs awesome!
I wanted to put a voltage regulator on the AC side that drives the headlight and taillight directly off the lighting coil and found the attached 6V regulator that is functionally equivalent (or so i think) based on inter-compatibility research i have done.
Anyhow, my question is, can i just tap into the yellow wire convenient, ground this puppy and be done?
Let me know your thoughts,
thank you
Martin
thank you
Martin
10 Aug 2020 21:16
Replied by Gr8uncleal on topic 1974 DT360A - voltage regulator installation
Yamaha recommend tapping into the blue in the headlight bucket - see link below.
You can mount it where you like - horn bracket and fork clamp bolt are popular. And you already know that it needs to be earthed!
yamaha-enduros.com/index.php/service-bul...e-voltage-regulators
11 Aug 2020 00:15
- msavitt
Replied by msavitt on topic 1974 DT360A - voltage regulator installation
thanks!
11 Aug 2020 09:38
- Flowart
Replied by Flowart on topic 1974 DT360A - voltage regulator installation
hello! I currectly having my headlight and taillight blowing on me on my dt360 1974 yamaha enduro. I bought that exact regulator but I installed it to my yellow right after it coming out of my mag. I see you guys mention putting it on the blue instead? And in the headlight bucket? I attached a wiring diagram is it the one I pointed to with arrows? Did that end up working for you?
Please let me know and thank you!
02 Apr 2022 21:18
Replied by MarkT on topic 1974 DT360A - voltage regulator installation
Posting the similar questions in 10 places is not helpful and will get confusing for you and everyone else.
Search on here and you'll find a ton of info. US model bikes have taillight running off battery. I asked you other questions in your first post on this that I'm not going to repeat here... BTW, is your battery good?
02 Apr 2022 21:40
- Flowart
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=334242829155&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Have a read of my post #13 on this thread.
1972 Yamaha LT2 - Restoring the Original Wiring - Page 2 - Vintage Enduro Discussions (yamaha-enduros.com)
03 Apr 2022 01:39
- msavitt
I've used this same regulator 3 times, cheap and works great and the little flickering light is cool too
03 Apr 2022 10:23
