Dt 250 No spark
  • CaptCove
  • CaptCove's Avatar Topic Author
Dt 250 No spark was created by CaptCove
Hey guys, I have a 1975 DT250 I'm restoring. Wheb I got the bike the source coil was removed because the PO was going to upgrade to CDI. Andy C. gave me assistance with soldering the source coil back on correctly and where the wires go. Tested the source coil and the resistance is correct. My problem now is no spark. Power is going to the plug, it will light up a test light but no spark. The points are within .012 and .015 and the gap I believe is correct. The ignition system is work because no power in off position, making power in on position. I was wondering what else should I be checking?
29 Jul 2020 08:10 #1
Replied by Pedalcrazy on topic Dt 250 No spark
Maybe check the simplest first...a different spark plug? Can’t hurt and pretty simple.
29 Jul 2020 08:15 #2
Replied by DEET on topic Dt 250 No spark
Where does the power come from? Kicking it over? A battery?
29 Jul 2020 09:43 #3
Replied by RT325 on topic Dt 250 No spark
I'm guessing its got a condenser fitted seeing things have been removed. The black from the mag loom can go direct to the plug coil to eliminate anything in between like switch etc. No battery required. Points opening & closing + contacting. Source coil not shorting somewhere. Once you have spark make sure you tighten the flywheel good & tight before starting.
29 Jul 2020 15:02 #4
  • CaptCove
Replied by CaptCove on topic Dt 250 No spark
Kicking it over generates power. Tried a couple different spark plugs still nothing.
03 Aug 2020 16:23 #5
03 Aug 2020 16:36 #6
Replied by Mothersbaugh on topic Dt 250 No spark
Have you cleaned the surface of the points by dragging 600 sandpaper or the equivalent through the points first one surface, and then the other?
03 Aug 2020 16:36 #7
