crankshaft thread pitch?
  • akara1
  • akara1's Avatar Topic Author
crankshaft thread pitch? was created by akara1
Anyone know what the proper thread size is for the primary gear end of the crankshaft on my 74 DT360? Id like to chase the threads with a die as they are messed up.
24 Jul 2020 23:27 #1
  • akara1
Replied by akara1 on topic crankshaft thread pitch?
For anyone that comes across this the answer was M18x1.0 RH thread, I picked up a thread cutting die from amazon for $13 and now the crank is sorted!
28 Jul 2020 11:27 #2
Replied by RT325 on topic crankshaft thread pitch?
Good one. I thought its probably the same as the sprocket nut but might be wrong. Talking mag side nuts for a minute, at work often we'd get a motor where someone had tried & failed to get the flywheel off & hammered the shaft so stuffed the thread. We had a set of adjustable dies, so i'd back the jaws out & go past the damage the adjust them up & wind it back off to sort it.
28 Jul 2020 15:20 #3
