Re:DT250 - Stuck in gear
- david.martin
DT250 - Stuck in gear was created by david.martin
Hey guys,
after reviewing the thread below I took the cover off, removed the basket and can see the selector but now I am stuck to understand what might be jamming the box in gear.
The bike will turn (with and without basket on i.e. the gear box turns nicely) just stuck in a gear (not sure which one!)
Any ideas?
:https://www.yamaha-enduros.com/index.php/forums/general-discussion/10011-dt400-stuck-in-gear-after-changing-shifter-seal?start=10
Any ideas?
12 Jul 2020 22:43
Replied by RT325 on topic DT250 - Stuck in gear
If its been full of water it could be one or all of the following. Cam plate plunger rusted to the hollow bolt ir slides --left side underneath at an angle. Selectors could be rusted to their respective shafts. Selector pins rusted into the selector drum. Things like that--or gears rusted on the shafts & not wanting to move sideways. Pull the bits out you can see there & grab the end of the drum firmly but carefully if that's possible & see if it'll crack free. Remove the cam plunger & spring first though.
The following user(s) Liked this Post: david.martin, LongStride
13 Jul 2020 06:01
- david.martin
Replied by david.martin on topic Re:DT250 - Stuck in gear
Thanks! Yes pulled the plunger/shift stopper and it was jammed but down in its bolt.
I’ll try and turn it manually.
Any ideas where to source a shift spring from?
Sent from my iPhone using Tapatalk
13 Jul 2020 11:55
- run103
Replied by run103 on topic Re:DT250 - Stuck in gear
looks like you should be splittin the cases. easier now than after you spend money and the seize a transmission shaft
Just talkin Doug
Just talkin Doug
13 Jul 2020 12:14
- david.martin
Yes, I’m only a few bolts away really!
Ok. I’ll strip her down. As you say, piece of mind.
13 Jul 2020 12:16
- run103
Just talkin Doug
Just talkin Doug
13 Jul 2020 12:47
- apex
- Content Contributor
Replied by apex on topic Re:DT250 - Stuck in gear
I had a Suzuki TS250 once that had water in the transmission, and the shift drum (iron) rusted and was seized in the case. Could be your issue too, was easy enough to free up & clean, didn't have to replace anything!
Allrighty Then
13 Jul 2020 15:25
- david.martin
But you had to split the case for that, correct?
Good thing with these motors as the gearbox side is less complex than its smaller cousin (175)..... word of wisdom... never take anything apart if you don’t intend on putting it back together within the same year :/
13 Jul 2020 15:33
Replied by MarkT on topic Re:DT250 - Stuck in gear
Interesting comment... I've always thought the 175 was easier than the 250/360/400!
And yes, great advice... taking lots of pictures is a great idea too! Unfortunately taking pictures is not a habit I've really gotten into... used to be an expensive hobby and when I grew up, pictures were only taken on very special occasions.
13 Jul 2020 16:38
- apex
13 Jul 2020 19:45
