DT360 / DT250, Throttle cable
Replied by RT325 on topic DT360 / DT250, Throttle cable
Sounds like the main problem starts from too much slack that you can't adjust out on the carb cap adjuster. Not sure if its a straight adjuster threaded into the carb cap or an angled one but whichever i'd either lift tha cable out of the adjuster or if it can;t be lifted out just wind the adjuster right off the thread purely to calculate how much too long the bottom inner cable is & then un-solder the nipple & move it up the calculated amount & solder it on. Sounds easy-- but only easy if you've had a bit of practice--like close to 60 years lol. I make all my own by starting with new Chinese scooter cables i saved from a skip. Good for brake & clutch. After all that, if the top cable is still too long to adjust out then might have to shorten that inner at the nipple in the junction box. Am i backing myself into a corner!!. Might be best to go & buy the right cable.
- mdscott
Replied by mdscott on topic DT360 / DT250, Throttle cable
Thanks RT325, I have made my own cables, but not very good at it.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
12 Jul 2020 18:01
#12
- mdscott
I found a solution for the above problem, may not be perfect but it worked. I had Venhill universal throttle cable kit and found a piece you would use to make a cable. Below is the picture, the spacing made it perfect. Now the carburetor cable is the correct length to operate the oil pump.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
