oil pump worm gear cavity full of oil
  • yamahoper
  • yamahoper's Avatar Topic Author
oil pump worm gear cavity full of oil was created by yamahoper
Should the cavity the worm shaft is in , and the space between the crankcase seal and pump be full of injector oil or does that indicate an internal oil pump seal leak?
09 Jul 2020 12:49 #1
Replied by mdscott on topic oil pump worm gear cavity full of oil
Yes,
but if wrong I'll admit it.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
09 Jul 2020 12:57 #2
Replied by MarkT on topic oil pump worm gear cavity full of oil
I agree with mdscott, bushing in case that worm shaft runs through is lubed by the Autolube oil.
09 Jul 2020 13:05 #3
Replied by nhsteve on topic oil pump worm gear cavity full of oil
I agree with MarkT.:likey
09 Jul 2020 13:20 #4
  • yamahoper
Replied by yamahoper on topic oil pump worm gear cavity full of oil
Thanks Guys, Its been awhile since I had the cover off a bike that's running a pump.
09 Jul 2020 14:01 #5
Replied by RT325 on topic oil pump worm gear cavity full of oil
Now that's something i've never thought of--if the shaft seal was faulty--& i've never had one--the oil tank oil could end up in the primary case just gravity fed. There's no pressure in the pump i think--& pressure is only in the pump stroke shaft to push it up to the cylinder. Has anyone ever had that drive shaft seal leak?, or would you even know, until the level came higher up the dip stick.
09 Jul 2020 15:17 #6
Whoa......that was a close one, I’ve been wrong way to many times lately.
:Buds
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
09 Jul 2020 15:19 #7
  • yamahoper
Thinking back I did have that happen, The tank emptied into the transmission.
Sometimes I wonder if I've forgotten more than I knew?
The following user(s) Liked this Post: MarkT, RT325, steffe50
10 Jul 2020 05:43 #8
