Dt 400 1975 indicator problems
Replied by Gr8uncleal on topic Dt 400 1975 indicator problems
I'll have two of what those little smilers at the end are having. Arse, I'll have to wait until tomorrow though!
03 Jul 2020 09:08
#21
- Vincent Hunt
Replied by Vincent Hunt on topic Dt 400 1975 indicator problems
Everything is now working as it should be. Cheers for all your help and i hope to speak to you again in the future when my next issue pops up ahah!
03 Jul 2020 09:31
#22
- Vincent Hunt
I tried what you said and everything is working as it should (fingers crossed!) Really appreciate your help.
03 Jul 2020 09:33
#23
- Vincent Hunt
New potential problem ahah! Took it out for a ride earlier and couldn't help notice the indicators flash at different speed depending on the revs. It seems they flash slightly faster at higher revs. Any idea?
06 Jul 2020 15:31
#24
Replied by MarkT on topic Dt 400 1975 indicator problems
Many standard-type flashers are load sensitive.... original type is exceedingly sensitive if that's what you have.
So if it's a slight change in flash rate, I'd say "normal".
06 Jul 2020 15:46
#25
I think that it's a new, modern type of relay Mark.
Vincent, would you be able to upload a short video showing the change of flasher rate? You should be able to do this with the bike parked up and in neutral - not expecting you to film as you ride along!
06 Jul 2020 23:46
#26
Age has nothing to do with it. Could be brand new. That's not the same as a modern design.
I'm still calling it "normal".
07 Jul 2020 05:21
#27
I'm also being a bit hard on the older flasher designs...
My older Jeep... at idle with lights and air conditioner blasting on high... flashes the turn signals slightly slower than when engine is revved up... it has a voltmeter and at idle with all the accessories on the voltage is lower than when rpm is brought up.
Flasher relay in the Jeep looks like the original one... Installing a brand new modern "LED" flasher that is bulb load insensitive might cure the slight change in flash rate... or might not.
07 Jul 2020 06:15
#28
