Gas cap hinge pin
  • meadeam
  • meadeam's Avatar Topic Author
Gas cap hinge pin was created by meadeam
My 74 dt360 gas cap may or may not be fully functional. It was unbolted from the tank when I got it, and just sitting on top. I think it works, but I know I am missing the little pin that it hinges on. I could use some heavy wire, or maybe even locate a suitable pin in a hardware store. If you've had to replace this part, let me know what you used.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
06 Jun 2020 11:33 #1
Replied by Rick C. on topic Gas cap hinge pin
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=401749100554&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by 2fishkev on topic Gas cap hinge pin
Or get ahold of DEET....
06 Jun 2020 16:22 #3
Replied by DEET on topic Gas cap hinge pin
I have them and the clip.
The following user(s) Liked this Post: meadeam
06 Jun 2020 18:50 #4
  • meadeam
Replied by meadeam on topic Gas cap hinge pin
I used a drill bit to pin it together for testing, and the lock is failing somehow. It pops open with just a bit of upward pressure on the cap.
It was very corroded when I got it, and I think part of the lock disintegrated. I'll take a picture later and maybe someone can tell if it is missing anything.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
08 Jun 2020 06:25 #5
Replied by nhsteve on topic Gas cap hinge pin
I got one of these. Not perfect as it is reproduction.
hvccycle.net/yamaha-fuel-cap-hinge-pin-9...-00-308-24623-00-00/
Should have thought of DEET before I pulled the trigger!! :Ugh
The following user(s) Liked this Post: 2fishkev, meadeam
17 Jun 2020 05:52 #6
