1975 MX250 Reed valve and manifold
  • tlh0824
  • tlh0824's Avatar Topic Author
1975 MX250 Reed valve and manifold was created by tlh0824
Hello,
I purchased a decent MX 250 top end for my DT250 and quickly noticed the DT reed valve and manifold were not the right size.
As I start to go down the rabbit hole- it looks like 75-76 MX 250 reed and manifolds are hard to find. I looked up the part# on the MX 400 and it 400 and they are the same, is this correct? Are there any other tricks (modifying parts) or a different model intake I can use even if it not the correct part#? It seems there are plenty of 74 mx 250 reeds and manifolds on eBay, any chance these would work?
thank you
Tom
02 Jun 2020 07:35 #1
Replied by RacerClam on topic 1975 MX250 Reed valve and manifold
What you are saying i s a bit confusing !! The manifold is part of the cylinder. Are you possibly refering to the reed cage ? Or the carb mountiing . If you are looking for the reed cage , afre you looking for stock replacement ? Or up grade to V force. I can help if i knew what you mean
Rich
racerclam
02 Jun 2020 08:48 #2
  • tlh0824
Replied by tlh0824 on topic 1975 MX250 Reed valve and manifold
Sorry, when I say manifold I am referring to the rubber carburetor mount
02 Jun 2020 10:58 #3
call speed and sport 866-455-6831 they should be able to get you what you need
racerclam
02 Jun 2020 11:13 #4
Replied by yamahoper on topic 1975 MX250 Reed valve and manifold
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=231803224620&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by smd3 on topic 1975 MX250 Reed valve and manifold
There’s a reproduction intake manifold made by hotfoot moto. It’s a good product, but expensive. It’s the only thing I’ve found available, so I guess that makes it a bargain.
03 Jun 2020 18:11 #6
I had issues with hot foot. Speed and sport as I said has what you need
Rich
racerclam
The following user(s) Liked this Post: FrankC, Pillsbury
03 Jun 2020 18:40 #7
