'75 DT 100 excessive smoking?
  • Wandwuff
  • Wandwuff's Avatar Topic Author
'75 DT 100 excessive smoking? was created by Wandwuff
Hello! My Dt100 is smoking way more than usual with the autolube system. I haven't changed anything but a carb rebuild so im not sure what it could be. The plug is fouled and i cant rev high because of it, could the issue be not revving enough so the oils not being burned fully? Or is there just too much oil? is there an easy way to tell if the autolube is pumping too much?
01 Jun 2020 19:28 #1
Replied by darinm on topic '75 DT 100 excessive smoking?
Crank seal is the most likely suspect.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
01 Jun 2020 20:27 #2
  • Wandwuff
Replied by Wandwuff on topic '75 DT 100 excessive smoking?
Any way to confirm that? My transmission oil is the same level it's always been at
Last edit: 01 Jun 2020 20:51 by Wandwuff.
01 Jun 2020 20:46 #3
Replied by MarkT on topic '75 DT 100 excessive smoking?
Thanks for posting the history. It's not the oil, it's too much fuel.
Did you put a "kit" in the carb with new jets? If so, put the original jets back in.
Also if the o-ring on the "jet setter" that seals the float bowl to the needle jet is missing, wrong, or damaged it will run super rich.
01 Jun 2020 21:00 #4
  • Wandwuff
No, it was the stock carb and i replaced or kept all the seals, as for the jets, stock that was in there was a 160 and i live at about 3700 feet elevation and it was running super rich to the point of not starting so i put the jets down to a 120.
01 Jun 2020 21:11 #5
First, Mark knows more than I do so follow his thoughts first. If the crank seal just started going bad, you levels would not drop yet. Is it the typical color smoke or more white than normal?
1972 Yamaha CT2 175
1997 BMW R1100R
2013 Yamaha XT250
01 Jun 2020 21:36 #6
That's a huge jump on the main jet... which by the way, has nothing to do with starting. There's a Mikuni tuning manual in the tech library that might be helpful.
I'm still going to say "carb o-ring" or something wrong in the carb. Just a guess.
Hope you figure it out! :Buds
01 Jun 2020 21:56 #7
  • Wandwuff
it's blue smoke. I also went from 160 to 140 then to 130 to 120 then 110 then i settled on 120 so i didnt just jump, i spent a lot of time tuning. what is the "carb o-ring"?
01 Jun 2020 22:06 #8
Replied by Mothersbaugh on topic '75 DT 100 excessive smoking?
#3 in the following diagram. must be in good shape, flexible and not cracked, or it will leak and cause what you are describing. Lube it just a little when you put the carb together each time.
www.partzilla.com/catalog/yamaha/motorcy...75/dt100b/carburetor
01 Jun 2020 22:34 #9
  • Wandwuff
last time i had it apart that was in good condition, i guess ill check on it again
01 Jun 2020 22:45 #10
