Top of piston identification marks
Replied by retro on topic Top of piston identification marks
I have a JT1 with a "96" on top & another with a "42 25" on it. What do those numbers mean? Thanx Much!
22 Dec 2020 08:08 #11
Replied by MarkT on topic Top of piston identification marks
Posting photos are always a good idea but in general the 96 is a standard and the 25 is first over.
22 Dec 2020 08:28 #12
Replied by Bdee on topic Top of piston identification marks
Curious what these numbers mean. From a CT3
22 Dec 2021 21:49 #13
Arrow points to exhaust port.  Numbers by arrow are likely some kind of manufacturing, inspector, or batch code.
The 975 should be the original size grading for a standard piston.  Standard bore on a CT is nominally 66mm so piston would have measured 65.975 mm when new.  Cylinder might still have inked code on skirts that are down inside case...  the 975 and size code on cylinder were used at assembly to select parts and end up with the correct piston to bore clearance when first assembled.
The following user(s) Liked this Post: Ht1kid, thumperstew, Bdee
23 Dec 2021 06:03 #14
Thanks so much for the info!
23 Dec 2021 09:36 #15
Replied by Drac56 on topic Top of piston identification marks
Hi All,
Pulled this one apart tonight,  carbon fouled top..   little scuff revealed this number.. im guessing standard bore for 70, 360, RT1.  Book shows 4 standard pistons, 79.96, 79.97, 79.98, 79.99 before they go oversize..
Do these numbers ring any bells? Just curious,  they mean absolutely nothing to me..
Im guessing, from the amount of carbon build on the top of the piston and the head, there was ring failure.. the cylinder looks pretty nice but… could still have issues that a bore gauge will have to sort out and a mic on the piston.
Thanks,
Drac
hope this link below works
drive.google.com/file/d/1kg2LAe78jydm3-c...GK/view?usp=drivesdk
Last edit: 21 Apr 2026 01:31 by Drac56.
21 Apr 2026 00:10 #16
Replied by pahiker on topic Top of piston identification marks
It asks for permission to access the picture.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
21 Apr 2026 01:37 #17
Pic is the best.  Or at least mention the numbers you're seeing.
21 Apr 2026 06:33 #18
Thanks for the feedback..
Of course, when i click the link, it works… tried the iCloud link the other night, entire library seemed to post, lol.. Imgur on the app store.. so many imgur links, downloaded a few, couldn’t get them to work upload a picture.
Numbers ..
7 space 2 arrow up ( front of piston) space K
9 space 3 space 2
they mean nothing to me.. except the arrow.
Gotta be a standard piston / bore..  mic’d it with the old Mitutoyo and it reads under the the standard bore hence i think the old mic needs calibration.. and of course , the setting gauge isn’t where its supposed to be..  this one hasn't seen daylight in a long time.
Anyway, thanks for the input here..
24 Apr 2026 08:59 #19
K means "keystone rings"
My guess is if you look close the second number is "985", not "932"
Anyway, the standard bore dimension is exactly that...  the size of the hole.  Piston is slightly smaller to provide required clearance.
From what you've said, my guess is it's a standard piston.
24 Apr 2026 09:30 #20
