Mushroom head gone on kickstand stone on 360 frame
  • mrstangblb
  • mrstangblb's Avatar Topic Author
The mushroom head on the frame of my 360 for the kickstand spring is gone, so I can’t put the spring on the stob sticking up to make it stay. Have you guys done anything besides welding to get something for the spring to catch? On the stand itself the mushroom head is still intact. (Sorry the title says “stone” instead of “stob” - that’s autocorrect for you)
Barry
KK4RXN
Jeremiah 29:11-13 / John 3:16
Last edit: 29 May 2020 03:29 by mrstangblb.
29 May 2020 03:27 #1
you could grind off the stub, drill, and tap where it was located, about a 6mm hole, and either thread in a 6mm bolt of the proper length then tack weld it, or use a slightly longer bolt and put a nut in either side of the flange so it locks in there. You could grind the head down to resemble the mushroom for a better look.
The following user(s) Liked this Post: mrstangblb, Gr8uncleal
29 May 2020 05:58 #2
  • mrstangblb
Great ideas - I always appreciate excellent input from the experts!
Barry
KK4RXN
29 May 2020 06:05 #3
Couple questions time..
Are you in the states?
Do you have access to a welder?
if so, I can send you one.
The following user(s) Liked this Post: MarkT, mrstangblb, Spitfire
Last edit: 29 May 2020 11:25 by Rick C..
29 May 2020 11:22 #4
  • mrstangblb
I am in South Carolina, and I can probably get access to a welder - the guy who is going to rebuild my engine should be able to get access to a welder.
Barry
KK4RXN
29 May 2020 16:44 #5
PM me your address, I will send you one.
The following user(s) Liked this Post: Makotosun, mrstangblb, HouseofEnduro
29 May 2020 20:10 #6
  • mrstangblb
I sure appreciate it! Let me know if the PM doesn’t get to you - just sent it.
Barry
KK4RXN
30 May 2020 05:15 #7
Message received, Mailed out today. ( around 2pm- my time. )
The following user(s) Liked this Post: Devin, MarkT, mrstangblb
30 May 2020 16:24 #8
Since I don't have a 74 RT here, I took the liberty to blue tape and marked it to the measurement of a 1978 DT125 and a 1970 CT1.Just a suggestion on that. Maybe somebody here with that bike will measure it correctly for you.
It is a tad bit long but will work out for you fine after you cut it !
Enjoy !!!
Last edit: 30 May 2020 18:38 by Rick C..
30 May 2020 18:28 #9
Instead of cutting it shorter, I'd grind the old one off flush, drill a hole the size of the new one, tap it into place and then tack weld or braze.
The following user(s) Liked this Post: Rick C., mrstangblb
30 May 2020 19:03 #10
