DT250 year ID??
  • Zeph
  • Zeph's Avatar Topic Author
DT250 year ID?? was created by Zeph
Seeing what year this may be??, I haven't gone to look at it yet, but may be a next project, thanks
Last edit: 29 May 2020 05:50 by Makotosun. Reason: mis spelled
28 May 2020 14:55 #1
Replied by 2fishkev on topic DT250 year ID??
Not much left to go on. By the gas cap, maybe 73 dt3? Can’t see exhaust and my other indicators are gone. Later front wheel too.
Last edit: 28 May 2020 15:28 by 2fishkev.
28 May 2020 15:27 #2
Replied by HouseofEnduro on topic DT250 year ID??
Reed valve, flip top gas cap, and long seat all indicate '72-73 model. Front brake hub is from a later bike.
28 May 2020 16:24 #3
Replied by Makotosun on topic DT250 year ID??
Really only way to be sure is the check the VIN and compare it on our tables in the tech library. Check frame head and also confirm the motor has the same number (if not get that too) Lots of motors and frames interchange, so you won't be sure if its the original motor, or just what it is, without the number.
The above guestimates look pretty close.
29 May 2020 05:52 #4
