75 DT400B Carb Leaking
- dew05001
75 DT400B Carb Leaking was created by dew05001
Hi All,
I went to try and start up my bike today and when I turned the fuel petcock “on”, fuel started pouring out of the carb. I think I know the part that is missing, but I don’t know what it is called.
I’ve attached a photo from a carb I found on eBay. Can anyone let me know what this part is called and where I might find one?
23 May 2020 22:05
Replied by MarkT on topic 75 DT400B Carb Leaking
That's a vent fitting, plastic, don't know where you could get one. It's not your problem though. Not even a chance it's your problem.
Try tapping on the float bowl a little... float could just be stuck open and often tapping a little will free it up.
Could be the float needle and seat are bad too... or some crud got stuck in the float valve.
23 May 2020 22:33
- dew05001
Replied by dew05001 on topic 75 DT400B Carb Leaking
Thanks so much for the suggestion. I’m going to take the carb apart and go thru it and give it a good cleaning.
That would make sense as to why I’ve been missing this piece for a while and this is the first time I’ve seen this problem.
Is it bad that I don’t have this vent fitting?
24 May 2020 09:16
Might be a little more likely to suck dirt in the vent hole as the path is shorter...
You might be able to make something
The following user(s) Liked this Post: dew05001
24 May 2020 09:52
- Lizeec
Replied by Lizeec on topic 75 DT400B Carb Leaking
Go to a decent auto parts store, they have a wide selection of plastic vacuum fittings, you can probably find a similar 90* nipple or possibly a straight nipple & glue it in there.
24 May 2020 10:01
- dew05001
Good idea, thanks!
24 May 2020 11:54
- JayB
Replied by JayB on topic 75 DT400B Carb Leaking
Does anyone know if this will work for his application?
hvccycle.net/oil-injection-nozzle-360-14...-00-1a1-14000-99-00/
I need one to for a spare DT400C carb, too.
Thanks!
Thanks!
24 May 2020 12:43
Right idea but oil injection nozzle is too small.
24 May 2020 13:00
