Relay wiring
  • wayno
  • wayno's Avatar Topic Author
Relay wiring was created by wayno
Done a search but still unsure if the correct wiring, ordered a relay for my dt400c for one listed on yambits, wires on the harness are brown(B) brown/white(L) and black(E), the terminals on the new relay are marked up X L and P which have to be wired to which colours?
Not the best at leccy.
Thanks Wayne.
Last edit: 22 May 2020 08:42 by wayno.
22 May 2020 08:38 #1
  • wayno
Replied by wayno on topic Relay wiring
No idea how that emoji got there should be B....
22 May 2020 08:43 #2
Replied by Gr8uncleal on topic Relay wiring
Brown to X, brown/white to L. Ignore the third pin and your black earth wire. You can also put whatever wattage bulbs in the flasher that you want.
22 May 2020 11:07 #3
Replied by Pete-RT1 on topic Relay wiring
This will come in handy.
Alan
Yamaha CT3 (in bits)
22 May 2020 16:19 #4
Replied by MarkT on topic Relay wiring
Make sure you insulate the "P" pin or mount it so it can't touch anything to prevent a direct short.
The following user(s) Liked this Post: wayno
22 May 2020 17:48 #5
  • wayno
thanks guys, worked a treat, next problem is rear brake switch linkage.
28 May 2020 05:16 #6
That's great, thanks for letting us know Wayne.
Plenty of cheap rear brake switches out there (eg Yambits in the UK) and they all come with one male and one female connector which plug straight into the main loom.
You just need to make sure that the fitment type is the correct one for your bike. I have seen two types of fitment - one where the switch sits in the loop on the frame and is held in position by a nut either side and a slightly later type where it is a push fit into the loop.
28 May 2020 07:31 #7
