1975 DT175 timing questions
Replied by deep6blue on topic 1975 DT175 timing questions
Unfortunately mine doesn't have that nice little notch.
20 May 2020 12:57 #81
Replied by Mothersbaugh on topic 1975 DT175 timing questions
deep6blue, try a dental pick, or an ice pick. Some type of sharp awl. If you can get at the end of it instead of the side of it, so much the better...
20 May 2020 13:09 #82
Replied by MarkT on topic 1975 DT175 timing questions
Deep6blue... Is it a Wiseco piston with the wire clip? Wiseco also used "spirolox" in their earlier pistons.
20 May 2020 13:28 #83
It's unknown the brand of piston. The only marking is the arrow. I've got a couple dental picks. I'll try that.
20 May 2020 14:18 #84
Yamaha uses both types of clips... I think all they sell now is the ones without the tang but older pistons don't have the hole to get in under the clip.
If you are replacing the piston, using a drill at an angle you can drill a little divot next to the clip to get a pick under the clip and pop it out.
20 May 2020 15:04 #85
  • GJVGC
  • GJVGC's Avatar Topic Author
Replied by GJVGC on topic 1975 DT175 timing questions
Dang it. More waiting time.
I’ll have to order the wiseco circlips and piston pin, the pin in the wiseco is longer than the oem I just got in the mail.
20 May 2020 18:39 #86
  • GJVGC
Random question
What bulbs are you using for the gauges?
I can’t find the correct 6v 3w bulb in any of my surrounding parts stores.
22 May 2020 10:58 #87
Replied by apex on topic 1975 DT175 timing questions
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=401736802982&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • GJVGC
^ perfect, thanks!
22 May 2020 13:36 #89
  • GJVGC
Putting the top end back together finally.
Do you guys apply anything to the cylinder gasket or head gasket?
26 May 2020 04:12 #90
