Multimeter
  • Free
  • Free's Avatar Topic Author
Multimeter was created by Free
I'm looking for a multimeter....I can't find the one listed in the manual (the yamaha pocket tester)....and I'm not supposed to use a digital.
What are you guys using?
1975 DT175
Last edit: 15 May 2020 01:41 by Free.
06 May 2020 21:25 #1
Replied by MarkT on topic Multimeter
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=164186706896&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by JimA on topic Multimeter
If you just need one to set the points, I used a test light with a 12 volt tail light bulb in it and powered it off of the battery. The light will dim when the points open, but does not go off completely. I have used my digital meter for everything else.
07 May 2020 18:43 #3
  • Free
Replied by Free on topic Multimeter
I'm trying to take in a bunch of info (new to me) and I read somewhere the magneto or something interferes with the digital reading...maybe its all readings.
1975 DT175
08 May 2020 22:16 #4
Replied by Gr8uncleal on topic Multimeter
  • Free
Well I get the yamaha pocket tester and this is what I find when I go to check if it takes batteries....
I'm guessing it was supposed to take two batteries and to was altered and then had a little fire. smh. idk. Some people really suck some times.
1975 DT175
Last edit: 14 May 2020 20:43 by Free.
14 May 2020 20:28 #6
