‘76 DT175 Piston Confusion
  • BWMoto
  • BWMoto's Avatar Topic Author
‘76 DT175 Piston Confusion was created by BWMoto
Hey guys,
I’m a long time reader and wrencher, but it’s my first time posting....
I recently purchased a cheap dt175 and had hopes of making it a fun project. I tore the motor down for paint and clean up. Decided to put a fresh set of rings in while I was there...
I purchased NOS piston rings, but it turns out they aren’t even close to fitting the piston that was in the bike. Any idea what this piston is and where I can find rings for it?
Thanks for the help!
19 Apr 2020 14:10 #1
Replied by Swoop56 on topic ‘76 DT175 Piston Confusion
That piston is an aftermarket Wiseco piston . The code 471 P2 is it's catalogue number .
I don't have a Wiseco catalogue so cant help with rings numbers .
They are numbered in imperial nominal bore size . They are readily available .
The following user(s) Liked this Post: JayB, LongStride, BWMoto
19 Apr 2020 14:47 #2
  • BWMoto
Replied by BWMoto on topic ‘76 DT175 Piston Confusion
Thank you so much!!!
19 Apr 2020 15:49 #3
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=292891378499&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • BWMoto
Thanks again Swoop!
I stumbled upon this website Wiseco Yamaha Pistons
Has a bunch of good info regarding part numbers for Wiseco Yamaha pistons.
20 Apr 2020 18:23 #5
