dt125F model identification & specs
- Youngdrakeo
Replied by Youngdrakeo on topic dt125F model identification & specs
absolutely. i have purchased it and should receive it next week.
73 CT3 modified, 74 AG175 MX, 79 YB100 x2 , 79 GT 80 ,2015 ducati scrambler ,honda CT70
- Youngdrakeo
Also FYI a yamaha Dx/RS125 Shares the same ratios as the ATMX asumming they also fit.
17 Apr 2020 20:50
#22
- Swoop56
Replied by Swoop56 on topic dt125F model identification & specs
Marcus , Steve didn't always copy his manuals off Oceania source material .
A give away as to the source on the CT manual , would be to check out the taillight unit .
US models were oval , whilst Oceania models used the earlier Tombstone shaped lens .
17 Apr 2020 23:25
#23
- Youngdrakeo
okay i have had both clutch covers off as i want to go back to autolube on my CT3. so stealing the pump from the AG
confirming pri ratios CT3 is 74/19 and the AG is correct at 77/17
note if changing primary drive gears you also need the matching pump drive gear as they are different pitches with differnt pri drive gears. you guys would have guessed that anyway. i only have a AG pump gear so will either need to run the AG #77 gear or source a CT one.
21 Apr 2020 22:47
#24
