couple of questions
- wayno
couple of questions was created by wayno
I have a U.S spec dt400c that I am rebuilding, found out today that the brake cable I bought a couple of months ago don't fit, it has the 8mm thread not the 6mm so am wondering if it's for the mx version? also the clutch cable doesn't seem long enough, tried routing it through the middle of the top yoke and along side but seems too short. next is a wiring question, when I stripped it down months ago I marked up the wires with masking tape A-A etc, putting it back I have a pink wire from the left handlebar cluster with nowhere obvious to go, any idea?
thanks Wayne.
thanks Wayne.
14 Apr 2020 08:37
- wayno
Replied by wayno on topic couple of questions
sorted the wiring bit, it's the horn I believe.
14 Apr 2020 08:56
Replied by MarkT on topic couple of questions
Yes, pink grounds the horn when button is pressed... there is also a brown wire to horn that is battery DC power with key on.
14 Apr 2020 11:52
Replied by RT325 on topic couple of questions
Just be super careful fitting brake cables that are too short to go the normal route. As when suspension is compressed & rebounds you 'could' get it caught on something [top fork yoke clamp bolt] [handlebar clamp bolts] etc then it'll pull the front brake on with unintended results.
14 Apr 2020 16:30
- wayno
didn't get as far as fitting for length on the front brake as the thread was too big, it's the clutch cable too short or I got the route wrong.
15 Apr 2020 01:17
Replied by Gr8uncleal on topic couple of questions
Morning Wayne and I hope that you and yours are all ok.
Did you buy genuine Yamaha or repro?
15 Apr 2020 01:51
- Fatthomas
Replied by Fatthomas on topic couple of questions
Yes you just find out that MX parts won't fit. Even if look the same they are not .
15 Apr 2020 12:51
- wayno
yes thankfully we are ok, bought them repro, ordered another from yambits but checked first on the thread size.
18 Apr 2020 09:52
