aftermarket shocks DT 175
aftermarket shocks DT 175 was created by otts
Hello all, working on a 1975 DT 175 I picked up for 200 bucks. Bike was sitting for years, got her running but the rear shocks are toast, bent along with rear rim. I have obtained a used rear wheel but have not had any luck looking for alternative shocks. Bike will be used to tool around some trails. I am not looking to spend much on this old bike, she is pretty beat up but has decent compression (122, 120). I have searched forums.
11 Apr 2020 12:29 #1
Replied by Eazy-X on topic aftermarket shocks DT 175
If you're not interested in performance and just want a quick fix then you just need any shocks that are the same size with the same mounting holes. I adapted some generic 125 shocks that looked period correct for my build. Doubt they'd be up to much on out on a trail but it's an easy swap at a later date.
12 Apr 2020 04:25 #2
Replied by Makotosun on topic aftermarket shocks DT 175
Measure the eye to eye length, then search on eBay for redwings which were a pretty common period correct aftermarket replacement.
12 Apr 2020 06:30 #3
Replied by otts on topic aftermarket shocks DT 175
Roger thanks found red wings on craigs that should work also 2018 triumph scrambler take offs that may work.
12 Apr 2020 10:23 #4
Replied by MarkT on topic aftermarket shocks DT 175
Might want to check the curb weight on the Triumph... probably a lot heavier bike than the 175... the Scrambler shocks might be way too stiff?
12 Apr 2020 10:32 #5
