1976 DT175 Headlight wiring question
  • MarkT's Avatar Topic Author
If you just want a headlight, leave it AC. Would be a good idea to install a regulator though as the 1976 came with one and had a higher output stator because they didn't have to worry about keeping the system as "balanced" as the earlier models.
Use a Yamaha hi-lo switch as it doesn't break contact completely when switching beams which could also blow the bulb. (Thanks to DEET for this info)
Yellow wire from stator will run the headlight.
24 Mar 2020 18:38 #1
  • downsouthoutwest
  • downsouthoutwest's Avatar
Replied by downsouthoutwest on topic 1976 DT175 Headlight wiring question
Thanks Mark!!!
26 Mar 2020 06:27 #2
