Out on the road! (And fiddling with the carb)
  • Eazy-X
  • Eazy-X's Avatar Topic Author
Went to the garage (gas station) to get some fuel on my DT175 Yay2
Originally I had a Chinese copy of the original VM24SS that the bike would have started with. Shock news! I got nowhere with it. What came with the bike was a Mikuni VM28 of some sort (similar to the Mikcarb on an Enfield Bullet) and that seemed to work a lot better...
Journey to the garage: brilliant, very easy going bike, love it! Only got it up to third gear but I probably shouldn't push it too much on brand new tyres. Note at this point the bike was running on fumes: a mixture of stale fuel and some premix (2 stroke oil pump also working so plenty of smoke!)
Fresh fuel in and the bike started stuttering on the way back. Couldn't get much above 3K. Oh yeah, if you read my other thread I swapped out the "mirror image" tacho gear parts and my tachometer now works :) Limped home in 2nd but as it's all suburban road (and quiet for some reason) no biggie.
Observations: good run, bad fuel. Bad run, good fuel! Starts and idles fine, won't start with choke. Last time I cleaned this VM28 I noted a #130 main jet (factory spec is a #140 in a VM24SS) and the pin was set as high as possible (clip at bottom.)
As it's the mid-range that has trouble that says to me main jet + needle adjustments. I'm thinking throw in a #140 + reset the pin to the middle position. Would welcome any suggestions of course!
24 Mar 2020 14:55 #1
I'd stay away from adjusting both at once. Start with the needle until the mid range clears up and then see how the top range is and adjust if necessary.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
24 Mar 2020 15:52 #2
Congratulations!
(I'd start by lowering the needle one notch at a time...)
24 Mar 2020 18:30 #3
  • Eazy-X
I thought I got it running well. The #140 jet seemed, initially at least, to give me a bit more power over 4K. Went round the block and even thought to myself "calm down! new tyres, if you recall" :)
Just got round the bend a few hundred yards from my house and it spluttered. Started again first kick - I really don't think there's any problems with the pilot jet, mixture screw or idling speed - a cough @ ~3K, then it revved fine, then it coughed again. I stopped at that point and at least found out it's an easy bike to push!
So, from cold fine. After a good warm-up mid-range goes rough. Any thoughts?
28 Mar 2020 10:10 #4
  • Eazy-X
So I think the problem was vacuum lock - certainly some sort of fuel starvation. I dismantled and reassembled the fuel cap and haven't had it splutter since... well, apart from when I forgot to turn on the petcock!
The following user(s) Liked this Post: Snglsmkr, darinm
09 Apr 2020 11:38 #5
Replied by Gr8uncleal on topic Out on the road! (And fiddling with the carb)
:likey
09 Apr 2020 12:27 #6
