Head or Head and Cylinder Retorque?
  • Snglsmkr
  • Snglsmkr's Avatar Topic Author
Head or Head and Cylinder Retorque? was created by Snglsmkr
When your under stimulated and your mind drifts to your Enduros you ponder things such as this:
On a fresh DT360 rebuild, should the head be removed and the cylinder retorqued after several heat cycles and some miles or is only the head of concern?
10 Jan 2020 19:06 #1
Replied by FrankC on topic Head or Head and Cylinder Retorque?
I am wondering the same thing. I don't think many did retork back in the day. My clymer says to, but it's alot of work if unneeded.
Last edit: 10 Jan 2020 20:29 by FrankC.
10 Jan 2020 20:27 #2
Replied by RT325 on topic Head or Head and Cylinder Retorque?
Leave it be unless you didn't tighten it properly in the first place.. The other thing i do if retorquing is crack it back enough to crack it 'just free' then bring it up to torque or you don't get a proper torque. Often the stud will just twist a bit [on small studs] & clicks the torque wrench without really moving the nut. Bigger nuts will just click without moving but if you crack it back & bring it up you'll be surprised how much further it goes to reach torque. [in my opinion].
The following user(s) Liked this Post: Snglsmkr, Pedalcrazy
10 Jan 2020 23:13 #3
Replied by Pillsbury on topic Head or Head and Cylinder Retorque?
After the 1st heat cycle, let it cool & then back each nut about a 1/2 a turn & re torque each bolt to full torque. Do these one at a time, it is not necessary to loosen all at once.
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
11 Jan 2020 04:51 #4
So I am thinking mine were loose. Didn't use a torque wrench, instead I put a 12mm wrench in between the fins and guessed the torque. Not something I would even at all reccomend. I did use the torque wrench upon assembly. Edit- so I am mentioning this now I had started to get an high eratic idle on start up that came from no where. Kept playing with the throttle cable. Even though spraying eether around the base gasket proved nothing or did not effect the idle, tightening the base cylinder nuts cured the problem. So I will probably adjust the air fuel mixture again because these settings were probably thrown off as the eratic idle caused me to compensate by adjusting them. Food luck on yours. Thank you also for pointing me to my base gasket leak also.
Last edit: 12 Jan 2020 18:45 by FrankC.
11 Jan 2020 10:38 #5
  • Snglsmkr
Replied by Snglsmkr on topic Head or Head and Cylinder Retorque?
Thanks for the guidance gentlemen. I'll do the head using the crack your nuts method and let the cylinder be. Fortunately it is less painful than it sounds.
11 Jan 2020 12:23 #6
I should point out my base gasket was a non standard .75 mm thick gasket material I got from Auto zone vs. the standard .5 mm Yami oem.
Last edit: 11 Jan 2020 13:28 by FrankC.
11 Jan 2020 13:28 #7
Replied by MarkT on topic Head or Head and Cylinder Retorque?
I bought an Snap-On open end torque wrench years ago for use on an engine I was racing that didn't have access in the fins for a socket like Yamaha did... has a ratchet head attachment or you can swap to different size open end wrench adapters. Not sure if they still make something like that and if they do it's probably $$$ these days.
The following user(s) Liked this Post: FrankC, Snglsmkr
11 Jan 2020 13:58 #8
Replied by RT360Fan on topic Head or Head and Cylinder Retorque?
Tohnichi makes very nice ones...
Chose your attachments
Or for a lot less money, motion pro makes a nifty torque wrench adapter...
The following user(s) Liked this Post: MarkT, FrankC
Last edit: 11 Jan 2020 21:26 by RT360Fan.
11 Jan 2020 21:23 #9
Great find! Same principle as the Snap On one I have.
Motion Pro tool is what I use on modern water cooled cylinders...
On the finned air cooled cylinders there wasn't enough clearance to get a ring wrench over the nut. Had to be an open end. (And I'm not sure Motion Pro made those 30+ years ago!)
Wow. That was a long time ago. Now I feel old. :S
11 Jan 2020 21:38 #10
